Hi experts,
Could you tell me the behavior of output when INA or INB pin detect OV/UV within t_PHL (t_PLH)?
In datasheet of 6.6 Timing Requirement, it defined t_PHL (t_PLH).
However, I would like to know how the output behaves when UV/LV is detected and the monitored voltage returns to the normal range (within t_PHL or t_PLH) before the output voltage starts to change.
I would also like you to answer the following examples:
1. If the voltage on the INA+ pin drops from 500[mV] to 300[mV] and then to 500[mV] after 10[us], how does the OUTA pin behave? (Does it transition Hi ➔ Lo ➔ Hi or does it remain Hi? If it transitions, what is its pulse width?)
2. If the voltage on the INA+ pin goes from 300[mV] to 500[mV] and then to 300[mV] after 10[us], how does the OUTA pin behave? (Does it transition from Lo ➔ Hi ➔ Lo or does it remain Lo? If it transitions, what is its pulse width?)
Yusuke
