The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
TPS25942L: fault pin
Part Number: TPS25942L
Hi Team,
in datasheet, it mentioned that Fault will be pulled down when UV, OV, OC, reverse current, thermal shutdown. In TPS25942L, it will latch in OC. so will Fault recover when OC remove? How about other conditions, will Fault pin recover automatically?  Thanks.
BRs
Given
