Other Parts Discussed in Thread: AWR2944,
By consulting the datasheet of TJA1463AT, it is necessary to pull STB_N low while keeping EN high to put it into standby mode. By setting the NINT polarity value to 0x3D through AWR2944, the radar will immediately reboot and cycle through a 70-second reboot process. The reboot reason is SDL_WarmResetCause_POWER_ON_RESET(PS: No reboot command was sent in the code, and the watchdog was disabled.). After approximately 20 minutes of rebooting, the radar will power down. May I ask how to correctly set the INT pin output of LP87745-Q1 to low level through AWR2944? And how to put the radar into sleep mode?
Thank you!
