Hi need to run this is without pwm control .i need to use as analog voltage like 3.3v in ctrl pin
Do you mean you want an analog voltage to adjust the LED brightness (LED current)?
BR
Patrick
Hi Subramanian,
What are your input voltage range, LED voltage and current? And do you need automotive grade devices only?
BR
Patrick
Hi Subramanian,
So you need automotive grade and LED current 350mA.
And what are your input voltage range and LED string voltage?
BR
Patrick
