TPS25947: e-Fuse that can be used to protect the charge/discharge battery
Part Number: TPS25947
Other Parts Discussed in Thread: TPS25948
My system uses a 2Cell Li-ion battery which is charged and discharged. At that time, I wondered if I could use e-Fuse instead of FET as a battery protection circuit.
I think it is difficult to use TPS25947 and I am looking for other products. Could you tell me if there is an e-Fuse that can be used for the battery charging and discharging system?
https://www.ablic.com/en/semicon/products/power-management-ic/lithium-ion-battery-protection-ic/intro/
Nishie
  • Hi Nishie-san,
    Can you check with the customer if they want a power switch or battery charger IC. From the request, it looks like they need battery charger IC but the part number used here is for power switch.
    Arush
  • Hi Arush-san,
    Thank you for your support.
    In addition to the battery charger IC, we are considering e-Fuse as a battery protection circuit. (Alternative to the battery protection IC)
    Therefore, we are looking for a product that can function as a power switch.
    Nishie
  • Hi Nishie-san,
    Apologies for delayed response.
    Can you tell me the exact issue with this part.? one issue I can think is you need bi-directional part? In that case, TPS25948 should be a good fit. It has a pin called RCBCTRL which can be used to enable, disable the reverse current blocking.
    One more issue which I see in general when trying to use an eFuse as battery charger circuit is lack of charge profiles.
    Arush
