TPS25751: BQ25792 REGN always active
Part Number: TPS25751
Other Parts Discussed in Thread: BQ25792
With the latest version of the USBCPD_Application_Customization_Tool (1.0.2) using the TPS25751 and BQ25972.
The REGN LDO of the BQ25972 is no longer disabled when not charging. This consumes more than 1 mA more than before with the previous version of the tool (exact version unknown, but done on August 26th).
Is there a known difference?
According to the release notes of the tool, the sleep mode has to be enabled manually, which has been done. (* Selecting a BQ part for TPS25751 disables sleep mode and enables current monitor, user can configure these settings through "Advanced Configuration"). Is this somehow related?
  • Hi Marcel,
    Thank you for reaching out!
    Could you further elaborate on what you mean by "when not charging" here? Is the USB PD adapter connected or disconnected? Is the battery fully charged?
    Aya Khedr
  • Hi Aya,
    Not charging means that the USB PD adapter is not connected. TPS25751 VIN_3V3 is switched off. The status of the battery is not dependent.
    BR Marcel
  • During debugging I found that the ADC on the BQ25972 is enabled. REG2E_ADC_Control Register bit ADC_EN is set. This is different from the old version.
    If I disable the EN_ADC bit (via I2C to TPS25751) from our firmware, then it behaves as before.
    BR Marcel
  • Hi Marcel,
    Thank you for debugging this. I can remove the ADC_EN setting. Could you please attach your latest json?
    Aya Khedr
  • Hi Marcel,
    See json and Full Flash Binary files below with the ADC_EN setting removed. If needed, please only make changes to the json in the "Advanced Configuration" window in the GUI. Changes on the questionnaire page may impact the ADC_EN setting being removed.
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/196/HUS_5F00_TPS25751_5F00_V1.1_5F00_Test_5F00_Remove_5F00_ADCEnable.bin
      "questionnaire": {
        "device": "TPS25751",
        "toolBuildVersion": "1.0.2",
        "answers": [
          null,
          4,
          4,
          1,
          1,
          0,
          3,
          3,
          1,
          1,
          1,
          0,
          0,
          0,
          8.39,
          3,
          0.4,
          0.04,
          0
        "vendorId": "0000",
        "productId": "0000",
        "version": "1.0.0.2"
      "configuration": {
        "data": {
          "selected_ace": [
              "register": 6,
              "data": [
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0
              "register": 22,
              "data": [
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                3
              "register": 40,
              "data": [
                0,
                0,
                46,
                1,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                3
              "register": 41,
              "data": [
                50,
                80,
                144,
                218
              "register": 50,
              "data": [
                0,
                170,
                42,
                44,
                145,
                1,
                32,
                44,
                209,
                2,
                0,
                44,
                177,
                4,
                0,
                244,
                65,
                6,
                0,
                244,
                65,
                6,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0
              "register": 51,
              "data": [
                2,
                44,
                145,
                1,
                16,
                44,
                209,
                2,
                0,
                44,
                177,
                4,
                0,
                244,
                65,
                6,
                0,
                69,
                65,
                6,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0
              "register": 55,
              "data": [
                59,
                192,
                18,
                65,
                180,
                144,
                1,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0
              "register": 66,
              "data": [
                26,
                0,
                8,
                0
              "register": 92,
              "data": [
                12,
                12,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                4,
                0,
                0,
                48,
                4,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                4,
                0,
                0,
                48,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0
              "register": 112,
              "data": [
                0
              "register": 119,
              "data": [
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                127,
                0
              "register": 122,
              "data": [
                0,
                0,
                0,
                0
              "register": 123,
              "data": [
                0,
                2,
                255,
                255,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0
              "register": 125,
              "data": [
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0
              "register": 126,
              "data": [
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0
              "register": 152,
              "data": [
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0
    Aya Khedr
  • Hi Aya,
    Can you please create me a new binary with this configuration: HUS_TPS25751_V1.4.json.zip
    Only change is battery charging voltage from 8.39V to 8.2V.
    BR Marcel
  • Hi Marcel,
    Please see attached.
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/196/HUS_5F00_TPS25751_5F00_V1.4_5F00_ADCDIS.bin
      "questionnaire": {
        "answers": [
          null,
          4,
          4,
          1,
          1,
          0,
          3,
          3,
          1,
          1,
          1,
          0,
          0,
          0,
          8.2,
          3,
          0.4,
          0.04,
          0
        "vendorId": "0000",
      "configuration": {
        "data": {
          "selected_ace": [
              "register": 6,
              "data": [
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0
              "register": 22,
              "data": [
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                3
              "register": 23,
              "data": [
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                2
              "register": 31,
              "data": [
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0
              "register": 32,
              "data": [
                0,
                0
              "register": 35,
              "data": [
                0,
                0,
                0,
                0
              "register": 37,
              "data": [
                0
              "register": 39,
              "data": [
                4,
                8,
                18,
                0,
                28,
                7,
                0,
                0,
                80,
                81,
                0,
                0,
                0,
                0
              "register": 40,
              "data": [
                0,
                0,
                46,
                1,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                3
              "register": 41,
              "data": [
                50,
                80,
                144,
                218
              "register": 43,
              "data": [
                64,
                0,
                0,
                0,
                2,
                0,
                0,
                0
              "register": 50,
              "data": [
                0,
                170,
                42,
                44,
                145,
                1,
                32,
                44,
                209,
                2,
                0,
                44,
                177,
                4,
                0,
                244,
                65,
                6,
                0,
                244,
                65,
                6,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0
              "register": 51,
              "data": [
                2,
                44,
                145,
                1,
                16,
                44,
                209,
                2,
                0,
                44,
                177,
                4,
                0,
                244,
                65,
                6,
                0,
                69,
                65,
                6,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0
              "register": 55,
              "data": [
                59,
                192,
                18,
                65,
                180,
                144,
                1,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0
              "register": 60,
              "data": [
                0,
                0,
                0,
                0,
                0,
                0,
                0
              "register": 61,
              "data": [
                0,
                0,
                0,
                0,
                0,
                0
              "register": 66,
              "data": [
                26,
                0,
                8,
                0
              "register": 67,
              "data": [
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0
              "register": 71,
              "data": [
                3,
                81,
                4,
                64,
                0,
                81,
                4,
                0,
                0,
                17,
                9,
                0,
                0,
                0,
                0,
                0,
                101,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                67,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0
              "register": 74,
              "data": [
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0
              "register": 81,
              "data": [
                0,
                0,
                0,
                0,
                0,
                0
              "register": 82,
              "data": [
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0
              "register": 85,
              "data": [
                24,
                0,
                0,
                0
              "register": 86,
              "data": [
                2,
                0
              "register": 92,
              "data": [
                12,
                12,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                4,
                0,
                0,
                48,
                4,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                4,
                0,
                0,
                48,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0
              "register": 93,
              "data": [
                0,
                0,
                0,
                0
              "register": 98,
              "data": [
                0,
                0,
                1,
                42,
                0,
                0,
                0,
                0
              "register": 100,
              "data": [
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                107
              "register": 108,
              "data": [
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0
              "register": 111,
              "data": [
                0,
                0,
                0,
                0,
                0
              "register": 112,
              "data": [
                0
              "register": 115,
              "data": [
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0
              "register": 117,
              "data": [
                0,
                0,
                0,
                0
              "register": 119,
              "data": [
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                127,
                0
              "register": 121,
              "data": [
                0,
                0,
                0,
                0,
                0,
                0,
                0
              "register": 122,
              "data": [
                0,
                0,
                0,
                0
              "register": 123,
              "data": [
                0,
                2,
                255,
                255,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0
              "register": 125,
              "data": [
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0
              "register": 126,
              "data": [
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0
              "register": 128,
              "data": [
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0
              "register": 149,
              "data": [
                16,
                39,
                0,
                0,
                128,
                185,
                42,
                0,
                64,
                156,
                0,
                0,
                0,
                0,
                0,
                0,
                16,
                11,
                8,
                7,
                1,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                47,
                155,
                1,
                0,
                16,
                39,
                0,
                0,
                8,
                16,
                8,
                9,
                1,
                0,
                1,
                0,
                59,
                2,
                255,
                255,
                0,
                0,
                0,
                0,
                0,
                0
              "register": 151,
              "data": [
                0,
                0,
                0,
                0,
                0,
                0
              "register": 152,
              "data": [
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0,
                0
          "bin_table": [
              "rights": 0,
              "register": 0,
              "data": [
                0,
                0,
                0,
                0
              "offset": 0
              "rights": 0,
              "register": 1,
              "data": [
                123,
                98,
                1,
                16,
                0
              "offset": 0
              "rights": 0,
              "register": 2,
              "data": [
                123,
                98,
                1,
                20,
                28
              "offset": 0
              "rights": 0,
              "register": 3,
              "data": [
                123,
                98,
                1,
                17,
                0
              "offset": 0
              "rights": 0,
              "register": 4,
              "data": [
                123,
                98,
                1,
                18,
                0
              "offset": 0
              "rights": 0,
              "register": 5,
              "data": [
                123,
                98,
                1,
                8,
                1
              "offset": 0
              "rights": 0,
              "register": 6,
              "data": [
                123,
                98,
                1,
                9,
                10
              "offset": 0
              "rights": 0,
              "register": 7,
              "data": [
                123,
                99,
                1,
                1,
                3,
                52
              "offset": 0
              "rights": 0,
              "register": 8,
              "data": [
                123,
                99,
                1,
                3,
                1,
                44
              "offset": 0
              "rights": 0,
              "register": 9,
              "data": [
                123,
                98,
                1,
                15,
                134
              "offset": 0
              "rights": 0,
              "register": 10,
              "data": [
                123,
                98,
                1,
                46,
                0
              "offset": 0
              "rights": 0,
              "register": 11,
              "data": [
                123,
                99,
                1,
                11,
                0,
                234
              "offset": 0
              "rights": 0,
              "register": 12,
              "data": [
                123,
                98,
                1,
                13,
                23
              "offset": 0
              "rights": 0,
              "register": 13,
              "data": [
                127,
                99,
                1,
                11,
                7,
                255
              "offset": 0
              "rights": 0,
              "register": 14,
              "data": [
                130,
                98,
                1,
                13,
                127
              "offset": 0
              "rights": 0,
              "register": 15,
              "data": [
                145,
                98,
                1,
                15,
                130
              "offset": 0
              "rights": 0,
              "register": 16,
              "data": [
                128,
                98,
                1,
                18,
                64
              "offset": 0
              "rights": 0,
              "register": 17,
              "data": [
                144,
                98,
                1,
                18,
                0
              "offset": 0
              "rights": 0,
              "register": 18,
              "data": [
                148,
                98,
                1,
                5,
                255
              "offset": 0
              "rights": 0,
              "register": 19,
              "data": [
                147,
                99,
                1,
                6,
                1,
                255
              "offset": 0
              "rights": 0,
              "register": 20,
              "data": [
                146,
                99,
                1,
                1,
                3,
                52
              "offset": 0
              "rights": 0,
              "register": 21,
              "data": [
                146,
                99,
                1,
                3,
                1,
                44
              "offset": 0
              "rights": 0,
              "register": 22,
              "data": [
                146,
                98,
                1,
                9,
                10
              "offset": 0
              "rights": 0,
              "register": 23,
              "data": [
                146,
                98,
                1,
                8,
                1
              "offset": 0
              "rights": 0,
              "register": 24,
              "data": [
                149,
                98,
                1,
                15,
                162
              "offset": 0
              "rights": 0,
              "register": 25,
              "data": [
                150,
                98,
                1,
                18,
                0
              "offset": 0
              "rights": 0,
              "register": 26,
              "data": [
                150,
                98,
                1,
                15,
                130
              "offset": 0
              "rights": 0,
              "register": 27,
              "data": [
                150,
                99,
                1,
                11,
                0,
                234
              "offset": 0
              "rights": 0,
              "register": 28,
              "data": [
                150,
                98,
                1,
                13,
                23
              "offset": 0
              "rights": 0,
              "register": 29,
              "data": [
                150,
                98,
                1,
                5,
                36
              "offset": 0
              "rights": 0,
              "register": 30,
              "data": [
                150,
                99,
                1,
                6,
                0,
                10
              "offset": 0
              "rights": 0,
              "register": 31,
              "data": [
                36,
                98,
                1,
                18,
                0
              "offset": 0
              "rights": 0,
              "register": 32,
              "data": [
                36,
                98,
                1,
                15,
                134
              "offset": 0
              "rights": 0,
              "register": 33,
              "data": [
                36,
                99,
                1,
                11,
                0,
                234
              "offset": 0
              "rights": 0,
              "register": 34,
              "data": [
                36,
                98,
                1,
                13,
                23
              "offset": 0
              "rights": 0,
              "register": 35,
              "data": [
                36,
                98,
                1,
                20,
                28
              "offset": 0
              "rights": 0,
              "register": 36,
              "data": [
                36,
                98,
                1,
                17,
                0
              "offset": 0
              "rights": 0,
              "register": 37,
              "data": [
                92,
                98,
                1,
                18,
                0
              "offset": 0
              "rights": 0,
              "register": 38,
              "data": [
                92,
                98,
                1,
                15,
                134
              "offset": 0
              "rights": 0,
              "register": 39,
              "data": [
                92,
                99,
                1,
                11,
                0,
                234
              "offset": 0
              "rights": 0,
              "register": 40,
              "data": [
                92,
                98,
                1,
                13,
                23
              "offset": 0
              "rights": 0,
              "register": 41,
              "data": [
                92,
                98,
                1,
                20,
                28
              "offset": 0
              "rights": 0,
              "register": 42,
              "data": [
                92,
                98,
                1,
                17,
                0
              "offset": 0
              "rights": 0,
              "register": 43,
              "data": [
                0,
                0,
                0,
                0
              "offset": 0
              "rights": 0,
              "register": 44,
              "data": [
                0,
                0,
                0,
                0
              "offset": 0
              "rights": 0,
              "register": 45,
              "data": [
                0,
                0,
                0,
                0
              "offset": 0
              "rights": 0,
              "register": 46,
              "data": [
                0,
                0,
                0,
                0
              "offset": 0
              "rights": 0,
              "register": 47,
              "data": [
                0,
                0,
                0,
                0
              "offset": 0
              "rights": 0,
              "register": 48,
              "data": [
                0,
                0,
                0,
                0
              "offset": 0
              "rights": 0,
              "register": 49,
              "data": [
                0,
                0,
                0,
                0
              "offset": 0
    Thanks and Regards,
    Chris
  • Great, thanks a lot!
  • You're welcome!
    BR,
    Chris
  • I also am having this issue.  Can you tell me where in the advance configuration of the TPS25751 the BQ25792 ADC is enabled/disabled?  I've gone through the register information for the TPS25751S and I haven't found where this is done.  I also need to change the default recharge threshold of the BQ25792 from the default of 200mV to 400mV.
  • Hi Michael,
    Can you submit a new E2E thread and provide your json and the ask again?
    The I2C writes are not contained in the register information and needs to be configured by TI currently.
    For I2C registers that the TPS25751 does not write to, you may need to use an EC or MCU to add additional BQ register writes using the I2Cw/I2Cr 4CC commands.
    Thanks and Regards,
    Chris
  • Yea as I was digging into this that was the conclusion I came to.  The changes that were being made appeared to be outside the scope of the online configurator even in advance mode.  I'll start a new thread.
