Part Number: BQ25176J
Hi Team,
I wanted to use the BQ25176J IC to one of the existing design and one problem is found is that the battery I am using should not charge below 10 degree Celsius and with the current datasheet it is stated that the charging will be done until 4 degree Celsius. Can I add a pull down resistor to the TS pin to change the threshold to >10 degree Celsius? If possible please share the relevant data to do so.
