Hi TI team,
Attached to you is my circuit but I do a modification connect the SHDN pin with my MCU to control the enable. Then, I observe a small voltage ramp up before my enable trigger the voltage.
My question is can I use the SHDN pin as my enable?
yellow - 3.3v (trigger signal) Green - -4.15V (output)
Thank you
