Hi team,
Could you please advise the leakage current at PG pin of TPS61378-Q1?
regards,
Hi team,
regards,
Hello Shinji,
The technical responsible person is in Chinese New Year. According to the datasheet this is an open drain output, so I assume that the resistance of this pin when it does not pull to GND is above 1Mohm. If this is not high enough for your application, please specify which leakage would be ok for you and then we can check if this is the case for this device.
Brigitte
