LMR38020SDDAR has no output and can only be restored when the input terminal is completely powered off and then powered on again.
The input VIN and EN pins of LMR38020 are directly connected together; The input circuit of LMR38020 has added a pmos as an input control switch, which may cause leakage and result in a voltage of around 1.2V on the input VIN and EN pins of LMR38020 when the module is powered off (pmos is turned off).
Can you help analyze the situation where the output of LMR38020 is locked? Even if it is powered on or off again, it cannot be restored unless the voltage of around 1.2V at the input VIN and EN pins of LMR38020 is discharged during power off to restore it.
