BQ76905: Standalone product and OTP Memory
Part Number: BQ76905
Dear TI Expert,
Please refer to attached datasheet.BQ76905_prelim_datasheet.pdf
  1. Can TI supply this IC as standalone?
  2. Can you provide updated datasheet if it is at full scale?
  3. It has One-time Programmable memory
Rahul Sharma
Lithion Power Private Limited
  • Hi Rahul,
    Please see my response below:
    1. TI can program customer setting out of the factory but this would require a spin and sufficient business case (similar effort as BQ7791514).
    2. Latest datasheet can be found on our device product page here: https://www.ti.com/lit/ds/symlink/bq76905.pdf
    3. Yes, this OTP is what is performed in the factory. There is an option to program the device with custom settings on powerup using MCU, but the setting will not be retained and need to be loaded by MCU in the event of a POR.
    -Luis Torres
