Other Parts Discussed in Thread: USB2ANY, BQ25798, EV2400, TPS25751
I want to connect USB2ANY to USB-PD_CHG-EVM-01 in order to connect directly to the BQ25798.
I saw that the charger on board is BQ25798.
I tried following the instructions in the E2E forum post, by connecting the I2C and lines to J7. But that seems not to work.
Perhaps I didn't understand the post correctly, I connected the I2C and GND to J7 only (no connections to the USB2ANY connector at all - I at one point try to connect P3V3 through J3 pin 5 - although this should not be necessary at all).
I'm assuming that there is some problem on the i2c line because multimaster mode is required?
Uri
