I would like to know if we can use the BQ25015RHLTfuel gauge with the BQ40Z50 PMIC.
Please share any existing consideration if the 2 aren't compatible.
Hi Antony, Thank you for your quick reply. Can you elaborate a little what do you exactly mean by this: Please ensure the charger connection is made to the PACK connection of the bq40z50, not directly to the cell itself." How they shall connect? a simple sketch will be sufficient. Thank you,
Laszlo
Hi Laszlo,
Below is an image of the schematic for our bq40z50-EVM, which is the typical implementation of our gauge. The red box shows the PACK connection, where the charger component will implement a charge current, along with where the application that will draw a discharge current should be attached. This allows for the gauge to protect the cell in case of any faults caused by the charger or application.
Anthony
