Other Parts Discussed in Thread: UCC21710
I am finishing a gate driver design using the UCC21710 gate driver IC for SiC MOSFETs.
I have been using the SLUC695 calculator tool to check my design and additional component values.
In the soft-turn off tab, I noticed that an additional set of R, C components (R_STO, C_STO) are being used to apparently control the pull-down current in the event of a DESAT/OC detection event.
However, the datasheet does not specify this need nor does it explain why this is needed.
As a result, I have 2 questions:
- Why is this R_STO and C_STO needed based on the SLUC695 spreadsheet?
- Do I need this in my implementation? How can I evaluate whether these components can be eliminated in my design?
Thank you very much for any advice you might be able to share.
