Hi, I am using LM25145RGYR in one of our design.
On the PCB, Measured voltage level on FB pin of regulator found to be 0.83V against 0.8V (+/-1% tolerance). This resulted in VR output voltage of 3.42 instead of 3.3V.
What could be the reason for this higher voltage seen on FB pin? How to go about resolving the same?
VR circuit details : Input Voltage - 12V; Expected Output Voltage - 3.3V; Rfb1 (Upper resistor) = 18k; Rfb2(lower resistor) = 5.76K.
Thanks, Dinesh
