Part Number: TPS61240-Q1
Can you please help to get the efficiency vs load current curve for VIN = 3.3V ?, As the datasheet only specifies for 3V & 3.6V.
Thanks a lot for your help !!
Vineet Anurag
Vineet Anurag
We will reply after weekend. Thanks.
Hi Vineet Anurag,
You can use our WEBENCH tools for other conditions' efficiency results. This data is based on our real bench test results. Thanks.
https://webench.ti.com/power-designer/switching-regulator/customize/152?VinMin=3.3&VinMax=3.3&O1V=5&O1I=0.3&base_pn=TPS61240-Q1&AppType=None&Flavor=None&op_TA=30&origin=pf_panel&lang_chosen=en-US&optfactor=3&Topology=Boost&flavor=None&VoltageOption=None
Aurora
