TPS2662: !shutdown input state?
Part Number: TPS2662
Hello
Using the TPS26621DRCx to protect an LED Illumination circuit for factory automation devices (multiple types, some with and some without microcontrollers).
If there is not a microcontroller in the circuit, the device is to be enabled all the time with auto-retry function.  Can !shutdown pin be left floating?   Is the pullup Rpu in figure 9.15 of the datasheet sufficient for this purpose?
thank you
