Other Parts Discussed in Thread: TPS552882
Hi, TI expert
The customer configured a circuit with TPS552882-Q1 and wants to check whether the output voltage ripple is at an appropriate level.
Below is the waveform of the measured output voltage ripple, and the probe was measured with a short Ground Cable & 20-MHz Bandwidth.
Vout=13.23V, but the ripple is 254.84mV. Is it okay to consider it as an appropriate level?
For reference, below is the schematic.
Please check. Thank you.
