Part Number: BQ78350-DEVICE-FW
Other Parts Discussed in Thread: BQ78350
Until now I have worked with the bq78350_R2. Now I have switched to the R3 version to use the balancing at rest, but it does not work.
In the post
I read that the relax mode is only entered when there is no voltage change. When using LFE or Li-Ion it is standard that after the charging process the voltages of the cells will drop. If I understand it correctly this means that the Rest function is still 0 and therefor the balancing at rest will not work. But i need the balancing to work as soon as possible. Is there a way to do it?
