I need the DCDC1 of TPS65073 at 3.3V at startup (default: 1.8V). If I use an external resistor divider (e.g. 1k5:1k8), the 1k8 resistor is in parallel to the internal resistor divider (which I can not disable, due to my microcontroller needs the 3.3V initially to be able to set the DEFDCDC1.DCDC1extadj bit.To calculate the correct 1k8 resistor value, I have to know the series resistance values of the internal resistors.
Thank you!
