This is a continuation of the thread below.
LM5148: EN hysteresis function - Power management forum - Power management - TI E2E support forums
I tried changing the resistance value of the EN resistive ladder using the LM5149-EVM, and got the attached results.
From these results, I surmise that setting the EN voltage low may cause unintended fluctuations.
You said that unintended fluctuations do not occur with the EVM you own, but have you ever changed the resistance value of the resistor ladder?
Please give it a try.
lm5148_en_hysteresis_function2.pdf
Please note that this measurement data was obtained at 48Vin.
If you check at a different voltage, the resistance value at which the symptoms are most likely to occur may be different.
