Hi team,
My customer is considering the LP5569.
Since it is used at the sensor input location, it will be used with analog dimming by adjusting the current value instead of PWM control.
Is the following method correct?
The LP5569 can be used with analog dimming by adjusting the current value instead of PWM control by setting the Chip_en bit in the CONFIG register to LOW,
as described in section 8.3.1.2.3.1 PWM Master Fader on EN/PWM Pin of the datasheet.
Kyohei
