Part Number: TPS543C20
Other Parts Discussed in Thread: TPS543B20, ,
Hello
I designed a DC/DC for 12V to 1.2V 20A load. The problem is that when I just use a 0.5ohm load which is around 2A, it is fine, but when I increase the load to 0.25ohm, it just shut down.
I removed Ilim resistor and it is OC but still it doesnot reach more than 2A! I simulated the design with PSpice and it is just fine. I attached the excel sheet calculator for your information
0815.TPS543B20_TPS543C20A_TPS543C20_Calculator.xlsx
