TPS5432: Schematic review and compensation circuit check.
Part Number: TPS5432
Other Parts Discussed in Thread: TINA-TI
Hi
I’ve attached design of the 5V to 1.8V buck converter circuit. Please review the design and share your feedback or suggestions.
I need to clarify mostly on my compensation circuit , Kindly share the comments.
 Best regards
Anjana
  • HI Anjana,
    Thanks for using E2E.
    We have a schematic proposal for the Vout = 1.8V in the data sheet which you can use in your case.
    If you would like to have a different compensation setting you can check the calculated behavior with PSpice or TINA-TI simulations or using our EVM.
    The feedback divider R10 and R16 are configuring about 1.46V on the output. Please use the formula in the data sheet.
    Sepp
