Part Number: TPS92692-Q1
Other Parts Discussed in Thread: TPS92692
I found while checking the manual that the TPS92692 has the following descriptions:
① Cycle-by-cycle current limit is accomplished by a redundant internal comparator. The current limit threshold is set based on the status of the internal PWM signal. The current limit threshold is set to 250 mV (typ) when the PWM signal is high and to 700 mV (typ) when the PWM signal is low.
② Cycle-by-cycle current limit is activated when the IS pin voltage exceeds 250 mV. The GATE and PDRV outputs are disabled, the SS and COMP pin capacitors are discharged, and the FLT pin is forced to ground.
I feel that these two conditions are a little conflicting.
By adjusting the IS resistor under MOS, it only "current limits" at low voltage; if the VIS voltage exceeds a "threshold limit", a restart will occur.What is this threshold?
I want to know under what circumstances the output current limit will be triggered and under what circumstances the chip restart will be triggered?
