TPS25751EVM: Can not download patch successfully
Part Number: TPS25751EVM
Other Parts Discussed in Thread: TPS25751
Hi Aya khedr,
We encountered an issue while downloading the patch and encountered an error in step ten, with the log showing NOT A PATCH.
The attachment contains our relevant code (tps25751. c), log (dowload_patch_log. txt), operating environment (operating environment. jpg), data captured using a logic analyzer (down_load_patch.kvdat), and KingstVIS tool(KingstVIS.exe). We need to install KingstVIS tool first, and then open the down_load_patch.kvdat file
Additionally, we confirm that the binary file we are using is a low region binary file, and that our low region data is included in the code.
Could you please help check where the problem may be
Best Regards!
Iris
 tps25751.c
1083	2.750893	1371	MCU	24	[M:msdk C:info F: L: ]: [MSDK][TPS25751] read_reg: reg 14, value 0b
1084	2.750902	1371	MCU	16	[M:msdk C:info F: L: ]: [MSDK][TPS25751] INT_EVENT1 ReadyForPatch bit is ready for patching.
1085	2.750906	1371	MCU	64	[M:msdk C:info F: L: ]: [MSDK][TPS25751] Step 1:  0B 00 00 00 00 00 00 00 00 00 00 02
1087	2.750921	1373	MCU	24	[M:msdk C:info F: L: ]: [MSDK][TPS25751] read_reg: reg 03, value 04
1088	2.750925	1373	MCU	16	[M:msdk C:info F: L: ]: [MSDK][TPS25751] PD controller is ready for patching.
1089	2.750937	1373	MCU	36	[M:msdk C:info F: L: ]: [MSDK][TPS25751] Step 2: 04 50 54 43 48
1092	2.750956	1375	MCU	24	[M:msdk C:info F: L: ]: [MSDK][TPS25751] write_reg: reg 09, value 06
1093	2.750960	1375	MCU	44	[M:msdk C:info F: L: ]: [MSDK][TPS25751]  Step 3: 06 80 33 00 00 35 32
1107	2.751018	1383	MCU	24	[M:msdk C:info F: L: ]: [MSDK][TPS25751] write_reg: reg 08, value 04
1108	2.751022	1383	MCU	36	[M:msdk C:info F: L: ]: [MSDK][TPS25751] Step 4: 04 50 42 4D 73
1158	2.812020	1391	MCU	24	[M:msdk C:info F: L: ]: [MSDK][TPS25751] read_reg: reg 08, value 04
1159	2.812026	1391	MCU	40	[M:msdk C:info F: L: ]: [MSDK][TPS25751] Step 5: 04 00 00 00 00 00
1174	2.812060	1393	MCU	24	[M:msdk C:info F: L: ]: [MSDK][TPS25751] read_reg: reg 09, value 40
1175	2.812061	1393	MCU	88	[M:msdk C:info F: L: ]: [MSDK][TPS25751] Step 6: 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1176	2.812065	1393	MCU	20	[M:msdk C:info F: L: ]: [MSDK][TPS25751] tps25751_write_patch patch size 13184
1300	4.155279	2748	MCU	24	[M:msdk C:info F: L: ]: [MSDK][TPS25751] tps25751_write_patch left patch size 60  00
1302	4.155301	2756	MCU	24	[M:msdk C:info F: L: ]: [MSDK][TPS25751] write_reg: reg 08, value 04
1303	4.155307	2756	MCU	40	[M:msdk C:info F: L: ]: [MSDK][TPS25751] Step 8: 04 50 42 4D 63 C7
1304	4.155370	2757	MCU	24	[M:msdk C:info F: L: ]: [MSDK][TPS25751] read_reg: reg 08, value 04
1305	4.155394	2758	MCU	16	[M:msdk C:info F: L: ]: [MSDK][TPS25751] Confirm CMD1 is cleared.
1306	4.155399	2758	MCU	40	[M:msdk C:info F: L: ]: [MSDK][TPS25751]  Step 9 :04 00 00 00 00 00
1312	4.155418	2779	MCU	24	[M:msdk C:info F: L: ]: [MSDK][TPS25751] read_reg: reg 09, value 40
1313	4.155423	2779	MCU	88	[M:msdk C:info F: L: ]: [MSDK][TPS25751] Step 10: 40 00 00 40 80 00 00 00 00 00 00 00 00 00 00 00 00 00
1314	4.155434	2779	MCU	88	[M:msdk C:info F: L: ]: [MSDK][TPS25751] Step 10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1315	4.155445	2779	MCU	32	[M:msdk C:info F: L: ]: [MSDK][TPS25751] Step 10 :00 00 00 00
1316	4.155450	2781	MCU	24	[M:msdk C:info F: L: ]: [MSDK][TPS25751] read_reg: reg 14, value 0b
1317	4.155453	2781	MCU	40	[M:msdk C:info F: L: ]: [MSDK][TPS25751] Step 11: 0B 00 00 00 00 00
1318	4.186443	2802	MCU	24	[M:msdk C:info F: L: ]: [MSDK][TPS25751] read_reg: reg 03, value 04
1319	4.186456	2802	MCU	40	[M:msdk C:info F: L: ]: [MSDK][TPS25751] Step 12:04 50 54 43 48 00
1320	4.186462	2802	MCU	20	[M:msdk C:error F: L: ]: [MSDK][TPS25751] Patch success but still not in APP mode, got: %.4s
