BQ40Z80EVM-020: Problem updating BQStudio Chemistry Library
Part Number: BQ40Z80EVM-020
Other Parts Discussed in Thread: BQ40Z80, BQSTUDIO, GASGAUGECHEM-SW
We installed BqStudio from your site and accordingly started setting parameters for our devices that use bq40z80 with Amprius batteries. Accordingly, the manufacturer told us to use the following chemical profiles ChemID (7652), ChemID (7602). However, in our case, the profile numbers reached 6115 and our Chemisty Version: 661. Therefore, we decided to update to a newer version (I don't know why it wasn't the latest one, because we just downloaded bqstudio), and accordingly downloaded zip ChemUpdate1158. We read that the update occurs by copying content from the chemisty folder to C:\ti\BatteryManagementStudio\chemistry.
After copying, we restarted and reopened the Chemisty tab in BqStudio. At this point, nothing was displayed, the window was empty and nothing was output. It seems that there is some problem. We tried to manually replace the files one by one, replacing all of them (Chem, chemdat.BAK, chemdat.tsv, chemdat, chemdat4, chemdat6, chemdat8 …. ) and found that the program gets this crash when we replace the file - chemdat6. It seems that there is some problem, can you help us? How to update to the new version so that we can use the profiles?
