Part Number: TLV62130A
For a new design i would like to power the transceivers of a FPGA with a buck converter.
Quite a while ago i have seen your presentation of low noise buck converter design: Low-noise and low-ripple techniques for a supply without an LDO PPT
So i would like to implement the solution with an extra LC filter with a bead, we would like to use the TLV62130A for that.
One problem is that the cuttof frequency of the LC filter has to be larger the loop bandwidth to have this double pole not affect the stability.
However with DCS control it is hard to estimate and control the loop bandwidth due the non lineair behavior, therefore we would to change the setup a bit.
If we connect the Vos pin to the output of the converter, then the fast non lineair loop isn`t so much impacted by the extra bead filter.
As far as i know is the upper voltage error amplifier quite slow, so we can connect this pin after the bead filter to regulate the DC drop away.
But we wanted to double check if we don`t forget anything and wanted to have your opinion.
We know you have some dedicated buck converters available for this, these inject the inverse of the bead filter response as far as i know.
But these aren`t available in our basket.
Kind Regards
Alexander
