Other Parts Discussed in Thread: TPS25751
1. If we are using TPS2575D as standalone PD source for smartphone charging, can the TPS2575D be used standalone in this application without using a battery or a BQ charger IC?
2. Is it mandatory to connect an external EEPROM or flash to the TPS2575D to define PDOs like 5V/3A, 9V/2A, 12V/1.5A, etc.? Or does the IC support default PDOs without EEPROM.
3. Can the TPS2575D be used as only source in a charging adapter application?
