Other Parts Discussed in Thread: BQ25895, BQ27Z746, BQ27Z561-R2, BQ27411-G1
I'm currently using the BQ25895M battery charger IC in a design powered by a single-cell 800 mAh Li-ion battery. I’m looking to enhance the system by adding battery fuel gauging based on TI’s patented Impedance Track algorithm, with the goal of achieving accurate state-of-charge (SoC) and time-to-empty predictions.
My primary objective is to implement a battery discharge model under real operating conditions to support accurate runtime estimation, improve power management, and enhance the user experience.
I would appreciate your guidance on the following:
Which TI Fuel Gauge ICs using Impedance Track
would best pair with the BQ25895M for a battery of this capacity (~800 mAh)?
Are there alternative single-cell, controlled fast charger ICs with MaxCharge
or similar functionality, that allow the system to run on a 5V power input (PIM/VBUS) and are known to integrate well with Impedance Track
-based fuel gauges?
Thank you for your support and for any design resources or reference materials you can share.
Martin
