May I konw what is the TPS51275B quiescent current, I have test my board ~23.5mA when EN1/2= high, 3.3V and 5V enabled, no load, Is it normal?
I only found VO1 supply current in datasheet.
Thanks!
Jeff
Thanks!
Jeff
Hi Jeff,
Looks like your part is switching. VO1 supply current is when the part is not switching. What you are measuring is not quiescent current but input current. For input current, higher values like ~20mA looks reasonable with no load at output. With higher load current, this input current will be higher.
This app note clearly mentions the difference between input current and quiescent current.
Gautam
Hi Gautam,
Sorry, should be output no load standby current. So you mean 20mA is reasonable, right?
But there have no this standby current in datasheet?
Thanks!
Jeff
Jeff, if the converter is switching then its normal as it will its corresponding loses included here.
