TLVM13610: alternative product recommendation
Part Number: TLVM13610
Other Parts Discussed in Thread: TPSM86838
It appears the availability for the TLVM13610 is poor at the moment, so I am looking for a suitable alternative. Is there a direct, available drop-in replacement from TI?
According to some searches, the TPSM86838 may be the closest (but not pin-to-pin compatible) and currently in stock with regular replenishments expected. Is this the best option?
The application requires 15V in (with UVLO support), 5V out, max. 8A.
Thank you in advance.
Mikael
  • Hi Mikael,
    Regarding availability - you may want to reach out to the local sales team/distributor to get more information. Placing orders for your requirements based on your production forecast can help with the supply reliability.
     If you are looking at alternatives - Yes TPSM86838 is a good alternative to look at. There aren't any pin-compatible alternatives for the specifications that you require.
    Taru
