Other Parts Discussed in Thread: LMR60410
Hi David,
I've assigned an expert to your post.
Andrew
Hello David,
Based on the requirements i believe the output voltage range is the limiting factor. I2C capable components such as TPS62868 could be a possible fit but its output voltage limited to voltage ranges depending on the OTP used. I believe feedback adjustable device such as LMR60410 is almost a good fit due to its high efficiency and low EMI, but its output voltage is limited to 1V min. Feedback adjustable devices would require a mechanism to switching resistors.
Oscar Ambriz
Thanks Oscar for your input.
I believe I have solved this problem in another fashion.
David
