Hi team,
I have a question about the LMR14010A chip. We want to know the chip's limit capability with capacitive load in a buck circuit (24V to 5V, inductor 100uH). Please help confirm the boundary value, thank you.
Lillian
Hi team,
Lillian
Hello Lillian
There are two limitations for maximum capacitance which IC can support
I would recommend checking WEBECH simulations to arrive at maximum capacitance limit for customer use case. Let me know if face any issue in doing it. I would be happy to help
Thank you
Onkar Bhakare
Hi Onkar,
Thanks for reply.
By the way, can you please confirm the approximate hysteresis voltage of the SHDN pin? The current specification only gives the startup voltage. Or is the hysteresis voltage of this pin determined by the external pull-down resistor, and the hysteresis current in the specification × the pull-down resistor value of this pin is the hysteresis voltage of this pin?
Lillian
Hi Lillian
you are absolutely correct; hysteresis voltage has to be determined from hysteresis current and EN resistor ladder used.
Thank you
Onkar Bhakare
Hello Lillian
Let me know if need further help. Kindly close the thread if your query has been resolved
Thank you
Onkar Bhakare
