Hi Team,
We are using TPS61041DRVT part and Input Voltage is 3.3V and Output current required is 30mA so i used to calculated and manually and also webench both coming different values. could you please help me.
Hi Team,
What do you want to calculate? Usually you can directly copy typical application circuit in datasheet.
Size is constraint for my design so i am planning to use 6.8uH inductor which is going to provide the power to LCD backlight is it fine?
