Hi Team,
TPS51116 circuit we have been using for several years has begun to not start up on many PCBs. Sometimes just changing the part will make it work and sometimes not. Looking closer at the circuit it appears that the low side MOSFET is not staying turned on. Below is the circuit.
What we found was by lowering R301(CS pin) to 1.8K we can get some of them to fire up but not all of them will work. Below is the low side gate drive on a working one.
Here is one with the reduced resistor to 1.8K but it still won't start up.
We know the low side gate drive is being turned off but we are not sure why.
The output current measured on a good working is ~435mA. Below is current after inductor with scope current clamp.
Here is good one starting up.
Here is bad one.
Also I had a bad CS resistor read ~300K and it fired up all the time. Some original value 5.36K fire up but not all of them.Then we switched to 1.8K and again some of them fired up but not all.
We tried this on 10 PCB's. There is something strange about this value. Would you have any ideas of where else to look in this circuit to help us resolve this issue.
Mike
