LMR51420: Thermal Resistance and Current Limit
Part Number: LMR51420
Hi team,
Could you support inquiries below?
Thermal Resistance RθJA
The IC ThetaJA Effective displayed in the WEBENCH® Power Designer differs from the RθJA specified in the datasheet. What conditions were used to determine this value?
High-Side/Low-Side Current Limit
The temperature characteristics in Figure 7-10. HS and LS Current Limit vs Temperature of the datasheet differ from the high-side/low-side current limit values in 7.5 Electrical Characteristics.
How should these be interpreted? (I understand the 25°C value on the horizontal axis of Figure 7-10 matches the value in 7.5 Electrical Characteristics.)
Kazuki Itoh
  • Hi Itoh,
    The thermal resistance for the IC in Webench is typically based on a measurement taken on the EVM and is more representative of a real application. The Table 7.4 is based on the JEDEC simulation standard for comparative purposes only.
    Use the Webench value for this design.
    For the current limit curve, that is a typical device curve to show how the current limit may change over temperature.
    The EC limits represent the minimum and maximum values.
    Ridge
