Other Parts Discussed in Thread: LM5185, LM5185-Q1
Hi team,
Is there a way to simulate of measure phase margin of PSR flyback using LM25184-Q1?
regards,
Hi team,
regards,
Shinji,
It is possible knowing the values of the RC Type II compensator used at the output of the internal E/A and simulating the loop gain of the PSR Flyback in DCM. Unfortunately, we do not have that tool available for LM25184-Q1. It is available for controller from the same family like LM5185. You can get the bode plots selecting the desired external compensator network, Lmag, VIN, Vout and Cout.
LM5185-DESIGN-CALC Calculation tool | TI.com
Thank you
Hi Manuel-san,
I am using LM25184-Q1. Is it possible to utilize LM5185-Q1 design calculator to draw bode plot?
If yes, could you please advise which value should I use for type II compensator?
regards,
Shinji,
I just asked the design engineer for these values. I will be back to you as soon as I get a response
Thank you
