TPS723: TPS72301DBVR
Part Number: TPS723
Hello.
Our actual application is using the TPS723 in the following conditions:
1. Vin = -7V
2. Vout = -5V
3. Output load is 185mA
Pdiss should be ~0.37W
We understand that the output current should be less than 200mA. We realized that there is a protection circuit that limits the current ~300mA min (550mA typ).
We are wondering if we can increase the output current up to 300mA approx. We also consider the change of Vin to -5.5V (or around it) in order to reduce the LDO dissipation (should be less than in actual application).
What would be the drawback of doing it? Will it continue to regulate to -5V? Is it safe in all conditions?
Thank you in advance!
  • Hi Pavel,
    Thank you for asking us!
    You will be able to source up to 300mA from the device before current limit triggers over all other recommended operating conditions. The exact threshold at which current limit triggers is somewhere must be between 300mA-800mA to remain in spec, and temperature dependence is responsible for most of that range. But usually, it is pretty close to 550mA.
    The only drawback is that you are no longer guaranteed to meet other performance specs when Iout > 200mA. It will continue to regulate to -5V, but load regulation will decrease accuracy a bit (0.002%/mA * 300mA = 0.6%), dropout will be proportionally worse, etc.
    Doing so is safe and does not risk damage. If all other conditions are safe for <200mA, it should be safe for 300mA.
    Reducing input voltage is a good way to cut down on power dissipation, just be aware that dropout may be a concern with 0.5V of headroom.
    Dropout is basically limited by the RDSON of the pass element, so it increases linearly with output current. Expect dropout to be 50% higher at 300mA. For safety, I would scale the max spec in the table to 750mV even though it's technically no longer a spec (after extending past 200mA) but an estimate of an extrapolated upper limit. On a practical level, 0.5V of headroom shouldn't necessarily cause dropout with typical characteristics.
    Gregory Thompson
  • Hello.
    This information is really helpful.
    Thank you so much!
