Part Number: TPSM365R6
I am using the TPSM365R6V5RDNR module in my design. The input supply range is 48V nominal, with occasional peaks up to 60V.
I have observed that when the input voltage goes above 55V, the IC starts heating significantly compared to lower input levels.
My configuration is as follows:
Input Voltage Range: 48V nominal (tested up to 60V)
Output Voltage: 5V
Load Current: 0.1A
PCB Design: Followed recommended layout from datasheet
Please advise on how to mitigate this heating issue.
