Other Parts Discussed in Thread: LM51772
LM51772 EVM Board Setup
Left side: power supply
Right side: Battery
To force a current flow from right to left, the output voltage of the LM51772 EVM board is set lower than the battery voltage.
Question 1: What happens if the reverse-set current cannot flow into the power supply? How high does the LM51772 EVM board increase the voltage?
General questions:
Question 2: Are there greater electromagnetic issues when using other inductors, for example the Coilcraft SER2915L-472KL, since this one is not completely enclosed?
Question 3: Is it possible to install the board in a steel enclosure without causing additional problems?
