TPS62A03: ENABLE min/max values in "6.5 Electrical Characteristics"
Part Number: TPS62A03
On the datasheet "6.5 Electrical Characteristics" under "ENABLE"
Are the values of the "EN high-level input voltage" and "EN low-level input voltage" in the incorrect "MIN" & "MAX" locations ?
Is the "EN high-level input voltage" 0.8V minimum and the "EN low-level input voltage" 0.4V maximum ?
    In fact it is not wrong, it is probably the way you interpret this description.
    For any voltage >0.8V, the EN pin will definitely be driven HIGH.
    For any voltage <0.4V, the EN pin will definitely be driven LOW.
    For voltages in between there is a chance of false read-outs by the device.
    I hope this helps!
    BR, Febin
