The TPS92200D1 is a TI step-down LED driver IC designed to drive constant-current LED loads.
1.If used as a 15-ohm heater (5W, 12V), is it feasible?(Will a DIMM be used to adjust the current?)
Hi Marco
TPS92200 regulated the constant output current.
Do you mean use a 1--ohm heater instead of LED as the output load? What kind of heater it is? Is it a resistor?
Do you need to adjust the output current? What's the target EE? What's the Vin, Vout?
Thanks and best regards.
