BQ25100: BQ25100 issue
Part Number: BQ25100
Dear expert:
At present, an abnormal output voltage (-0.005V) of an IC chip was found. After replacing the IC, the output (4.25V) was normal. After cross-verification, it was confirmed that the abnormal output of the IC chip was the cause. Then, the pin performance between the abnormal IC was measured. Confirm that the internal circuit connectivity of the chip is normal (the following data). The voltage output failure cannot be identified as the root cause. We need the manufacturer's assistance to conduct a failure analysis of the IC chip
引脚
阻抗
连通性
1-1
0.585V
正常
1-2
0.455V
正常
1-3
0.457V
正常
2-1
0.451V
正常
2-2
0.604V
正常
2-3
0.604V
正常
