TPS7A49:Question About R2 Calculation
Part Number: TPS7A49
Dear team,
I am currently reviewing the TPS7A49 datasheet and have a question regarding the calculation of R2 in the adjustable output configuration.
In equation (2) on page 14, it is written as:
VFB(nom)/R2>5μA
However, in equation (4) on page 17, the calculation is shown as:
VREF(max)/R2>5μA
Could you please clarify which voltage—VFB(nom) or VREF(max)—should be used for calculating R2 correctly?
Thank you very much for your help.
Maia
  • Hi Maia,
    Thank you for asking us!
    VFB(nom) =1.185 is the stricter condition, so it's best to design around equation (2) on page 14.
    The feedback network requirement is mostly to add a minimum load, so the phase margin doesn't become negative (which it happens to be at zero load) over any of the other Recommended Operating Conditions. If you are using an output capacitor that is larger than the minimum recommended 2.2uF this requirement is less strict.
    Gregory Thompson
