Could you please confirm if our understanding of the UCC2895x Excel Design Tool (SLUC222) is correct?
The Bode plot generated by the tool is based on Voltage Mode Control results.
The tool does not provide any option to switch between voltage mode and current mode.
For designs using Current Mode Control, the RSUM pin configuration and compensation network must be adjusted manually according to the datasheet and application notes.
Could you kindly confirm if the above understanding is correct?
Conor
