Hello, my name is Hasegawa.
I'm designing a business-use handheld terminal equipped with the BQ27320.
I have a question about the BQ27320 datasheet.
1. Regarding the conditions for overwriting the Learned Full Charge Capacity.
Is the Learned Full Charge Capacity only overwritten when the learning conditions described in Specification 1.1.3 are met?
2. Regarding the setting to retain the Design Capacity value.
Is it possible to always retain the Learned Full Charge Capacity as the Design Capacity value?
(Is it possible to configure it so that capacity learning does not occur?)
3. Regarding rewriting the value after capacity learning.
Is there a way to reset the Learned Full Charge Capacity to the Design Capacity value after capacity learning has progressed?
Thank you in advance.
