Part Number: LP5560
Other Parts Discussed in Thread: LP5524
Hi Team,
Can customer use LP5560 CTRL pin for PWM dimming function to control LED current/brightness?
Thanks.
Hi Peter,
Yes, the CTRL can be used directly to control LED current/brightness. But how much is the PWM frequency required?
If you want to find a LED driver that can be controlled on/off directly, recommend to take a look at the LP5524.
best regards,
Felix
Hi Sir,
I also suggested LP5524, but customer only needs 1 ch and PWM control function.
If LP5560 can be controlled by PWM via CTRL pin, that is great!
