We are implementing the BQ25798 in a power-management solution and would like to add a mechanical ON/OFF toggle switch to fully turn the system on or off. However, after reviewing the datasheet and available application notes, we could not find any guidance on how to implement a complete system power-enable or shutdown using this device, since the BQ25798 does not provide a dedicated EN pin or an explicit method for disconnecting the system load. We would like to know whether Texas Instruments could provide recommended guidelines for implementing this feature, whether through the QON pin, SYS/BAT control, the use of external FETs, or any other TI-validated approach, while ensuring safe operation within the specifications of the BQ25798.
Thanks in advance
Best regards
