TPS40055: Can the TPS40057 be substituted in an application using the TPS40055
Part Number: TPS40055
Other Parts Discussed in Thread: TPS40057
We have an existing product using the TPS40055 with no issues.
Can the TPS40057 can be substuted as a direct replacement in this case for the TPS40055 with no issues? The reason is for derisking supply chain management.
I understand the only difference is that the TPS40057 can handle Vout prebias. Is this mainly for battery charging applications where you have a battery connected at the output, before the device is powered ?
